2001 Ford F150 Changing rotors
2001 FORD F-150
17,200 MILES • V8 • 2WD • AUTOMATIC
INDIAN
How do you remove the rotors, these are different from others that I have changed
Feb 13, 2008 at 7:18 AM
2CARPRO JACK
  • 11,533 POSTS
Remove grease cap, pull kotter pin, remove cage and unscrew the nut.Reverse for assembly tighten nut to 30 ft lbs while spinning rotor clockwise. Then loosen nut, then tighten 17-24 ft lbs while spinning counter-clockwise, then back spindle nut off 175 degrees of rotation.Rotate clockwise and tighten nut to 17 inch lbs. Install cage and new kotter pin
Feb 13, 2008 at 8:03 AM
