Remove grease cap, pull kotter pin, remove cage and unscrew the nut.Reverse for assembly tighten nut to 30 ft lbs while spinning rotor clockwise. Then loosen nut, then tighten 17-24 ft lbs while spinning counter-clockwise, then back spindle nut off 175 degrees of rotation.Rotate clockwise and tighten nut to 17 inch lbs. Install cage and new kotter pin
Feb 13, 2008 at 8:03 AM
