2001 Ford F150 change oil pump
2001 FORD F-150
TEKO02
Engine Mechanical problem
2001 Ford F150 V8 Two Wheel Drive Automatic
I have a ford f-150 in wich the oil pump stoped working. the engine did not locked, Is it possible that by channging the oil pump the will crank again?
Nov 4, 2008 at 4:36 AM
MASTERTECHTIM
  • 4,750 POSTS
st likely no. once a engine is run with no oil pressure, internal engine damage is likely. how do you know the pump is bad? is it losing oil pressure while driving? at higher rpm? does the enigne knock already? does the engine run?
Nov 4, 2008 at 5:25 AM
