AC and HVAC blowing fuses
2001 FORD F-150
235,550 MILES • 6 CYL • 2WD • AUTOMATIC
JOE DEPEW
my ford f150 blows fuse #5 when I run ac or heater after about 5 min. of running them , and then will stick in the cool or hot mode which ever one Im using and wont let ac work or heat adjust which ever one it is stuck on any help for me
Oct 5, 2009 at 8:14 PM
Lets try removing the compressor clutch trigger wire and replace the fuse. Here are wiring diagrams that show how the system works below. Also I have included the fuses just in case.
Oct 13, 2009 at 8:54 PM
JOE DEPEW
You are a genius! I replace the fuse and disconnect the compressor and the problem is gone! I guess I need a new compressor.
Oct 17, 2009 at 7:52 AM
Good find on that. here is a guide that can walk you through the steps.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 17, 2009 at 4:01 PM
