Engine Mechanical problem 6 cyl Two Wheel Drive Automatic
My sons 2001 F150 has no fuel pressure. I have checked the relay and fuse, inertia switch and filter. All are fine. I disconnected the fuel line from the filter and turned the ignition on and no fuel pumps out. I hear a brief noise in the tank as if the pump starts and then stops. My question... is there any thing else I should try and/or check before dropping the tank and replacing the pump, which I had already replaced 7 months ago. I would really appreciate any help I can get.
Jul 9, 2010 at 2:32 PM
