2000 Ford F150 transmission slippage
2000 FORD F-150
JO0418HN
Transmission problem
2000 Ford F150 V8 Four Wheel Drive Automatic 108k miles
live in the mountains,no load in truck,climbing a slight grade,truck bucks,manually downshift,stops bucking,added lucas trans additive,some help,vin#1ftrx18w2ynb84910,born date 5/00-question should i add more additive,seafoam maybe,also what is the trans #4r70w or what #,thanks jo0418hn
Feb 10, 2010 at 2:37 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
These additives are not a cure all, at best they may just mask a problem, the slippage is a sign of worn clutch packs leaking servos or low line pressure, it really needs to be checked out now before you do some real damage driving it about, get it seen to by a qualified trans tech before its to l ate.
mark (mhpautos)
Feb 11, 2010 at 3:00 AM
