My steering wheel shakes when I apply the brakes?
2000 FORD F-150
DONLU2
With light brake pressure there is a lumping pulsing of the brakes like they are on and off also feel this when jacking vehicle and running when jacked up on one wheel rear. is there a way to disable rear abs system for troubleshooting? Replaced one brake drum it seems slightly better but still pulses?
thanks for any ideas or help - Don
Mar 1, 2008 at 4:56 PM
The best way to see which brake is having the problem you should jack up each wheel and spin it with someone holding their foot just a little and the brake pedal. This way you can see which one is warped and replace the rotor.
Here is a guide to help you get he job done:
Apr 6, 2021 at 12:05 PM
DONLU2
Great guide, I did what you said and found the left front rotor has causing the issue so I replaced both. All fixed.
