2000 Ford F150 gas gauge
2000 FORD F-150
119,000 MILES • V8 • 4WD • AUTOMATIC
A.STAKER
I recently had my truck parked on a fairly steep incline overnight, now the gas gauge is stuck between .5 and .25 tank. What can I do? Thanks
Oct 21, 2008 at 1:55 PM
DOCFIXIT
  • 18,828 POSTS
Maybe float is stuck have you tried adding fuel to see if that might free up. Or grab the bed and shake.
Let me know if does not work and will trace wiring down.
Oct 21, 2008 at 2:30 PM
A.STAKER
[quote:c1288e6b15="Docfixit"]Maybe float is stuck have you tried adding fuel to see if that might free up. Or grab the bed and shake.
Let me know if does not work and will trace wiring down.[/quote:c1288e6b15] I did fill up tank and that did'nt work, have'nt tried shaking the bed. I did hear that lightly tapping the gas tank with a hammer may free up a stuck float. Any truth to that? Thanks
Oct 22, 2008 at 10:01 AM
DOCFIXIT
  • 18,828 POSTS
Probably not good idea shaking safer. Let me know if you need wire ID to gague circuit.
Oct 22, 2008 at 11:23 AM
A.STAKER
Shaking the bed did'nt work. Any other suggestions? Thanks
Oct 24, 2008 at 11:36 AM
DOCFIXIT
  • 18,828 POSTS
Need to get truck on a scanner to dianose system. Your truck has ability to trace down problem via scanner.
Oct 25, 2008 at 10:53 AM
