2000 Ford F150 AC leak
2000 FORD F-150
111,350 MILES • V8 • 2WD • AUTOMATIC
DAVEM
Ive got a 2000 ford 150. It has a small "pin" leak at the top of the accumulator/collector tank. I believe it is made of aluminum. I released all the pressure and sanded the area where the leak is and cleaned it. I then applied some JB weld to it and let that dry completely. I then recharged it with the refridgerent. It worked good and blew out some cold air but only held for about a day, and all the refrigderent leaked out again. I know this cant be a rare problem because we have a chevy astro van with a leak caused by a wireing harness rubbing against the AC lines which is the same cause of the leak in my truck. I dont know what else to do. Should I try alumi-weld which is like JB weld but for aluminum? Or do they make any fix for this kind of problem? Please help! THANKS!!
Feb 10, 2008 at 11:59 AM
MERLIN2021
  • 17,250 POSTS
Why don't you just replace it? That's the SURE fix...
Feb 10, 2008 at 12:01 PM
J.S.T.
Hello I'm an AC Tech by trade and I have the same problem as Daven. I would like to Repalce the ac accumulator,but I see that the lines that go into the Evaporator don't come apart.. Do I have to remove the dash, and remove the evaporator to get them apart??? I just need to remove the accumulator...
May 17, 2011 at 7:48 PM
MERLIN2021
  • 17,250 POSTS
an ac tech? use the ford line tool, wrap around line and push it into the connection pull lines apart.
May 18, 2011 at 9:03 AM
