1999 Ford F150 sensors
1999 FORD F-150
ROGCO
Computer problem
1999 Ford F150 V8 Four Wheel Drive Automatic
i'm have 3 dtcs coming up a p1549 witch is IMCC on bank B . and a p1137 and p1138 just woundering how i fix those problems or were those sensores are.. thank you
May 15, 2008 at 8:04 PM
FLEXY5
  • 512 POSTS
Are you sure it is a v8? The 4.6L and 5.4L didn't have an IMCC option on it. The 4.2L v6 may have had it. It's an intake manifold control system that works in conjunction with the EGR system. There should be a rod on each side of the intake, just before it attaches to the heads. The 3.8L engine on other models had issues with the clips falling off the controllers. If they are vacuum operated, the vacuum pod may be bad. You can test them using a vacuum pump. All three codes are related to this system. Test the pod and check the clips, then post back and we'll go from there.
May 15, 2008 at 8:43 PM
