1999 Ford F150 removal of gas to replace fuel pump
1999 FORD F-150
93,000 MILES • V8 • 2WD • AUTOMATIC
GBENBOW
The book says to siphon out the gas then remove tank. there is an anti-theft screen in the tank, so I cannot get a line into the tank. How can i siphon out the gas? Tx
Jun 29, 2008 at 7:17 PM
BLACKOP555
  • 10,386 POSTS
is it full of gas/ it wont be that heavy, just support it with a jack. you will hve to remove the fuel filler line and see if you can get a line in the tank, or just drop it enough to loosen up the vapor port on the top and stick a hose through there.
Jun 29, 2008 at 8:18 PM
