1999 Ford F150 Idle
1999 FORD F-150
127,000 MILES • 6 CYL • FWD • MANUAL
ACALVERY18
Hi. My truck runs fine it just idles up high when i push in the clutch or when it is sitting still. I have replaced the air filter, fuel filter, spark plugs, and the throttle control sensor. It is still idling up. Can u please tell me what it is?? Thank you so much. ~Amanda~
Feb 15, 2008 at 4:14 PM
MASTERTECHTIM
  • 4,750 POSTS
you either have a big vacuum leak or your idle air control valve is no good and needs to be replaced. look at engine and listen for a hissing noise and see if any vacuum lines are broken, if ok then replace the valve. hope this helps
Feb 15, 2008 at 4:35 PM
