1999 Ford F150 how to change starter
1999 FORD F-150
133,000 MILES • V8 • FWD • AUTOMATIC
JAY2782
Starter
Aug 19, 2010 at 10:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the positive post of the battery cable. Underneath the passenger side of the truck you will find the starter. It is bolted to the bell housing of the transmission. It will take a 13mm socket and extension. After removing the two bolts you will be able to pull the starter out of the housing area and disconnect the wires on the solenoid.
Aug 19, 2010 at 4:25 PM
