Recently I am experiancing my transmission shifting strangley. The reverse is no problem at all but forward gears have me wondering if there is a major issue.
When I put it in drive it hesitates and then seems to slip into gear. I have no problems when shifting up after it is in gear. Recently I have had to rev the engine up before it snaps into drive. I replaced the fluid and the filter and it helped slightly for about a month. Now it is back to the same senario and it is slipping out of gear when I stop or let the engine under 1000 rpm's requiring me to rev the engine to about 2000 rpm's to re-engage. I have always had a problem down shifting in that it will jump to 4000 rpms bfore kicking down and it slams into gear.
There are no leaks from the outside of the pan or seals that I can see.
Oct 22, 2008 at 6:37 PM
