1999 Ford F150 code P-1747
1999 FORD F-150
14,800 MILES • 6 CYL • 2WD • AUTOMATIC
LUIS RODRIGUEZ04
where is this part located on the transmission my overdrive botton light is blinking and truck jerks and slip from 2 to 3
Jul 17, 2009 at 9:10 PM
BMRFIXIT
  • 19,053 POSTS
P1747 EPC Circuit Shorted Or PCM. (Output circuit check, generated ONLY by electrical conditions.) tech tip By WATERLOO TRANSMISSION quick tip on P1747. Make sure you pull the pan before doing any diag.. Most of the time the trans is wiped out with a lot of clutch material and fine metal. If not then you might have caught the problem before it took out the trany
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_422.jpg
check wiring harness and suspect bad tranny if have a lot of material in tranny oil pan
Jul 17, 2009 at 9:31 PM
