1999 Ford F150 Blow spark plug
1999 FORD F-150
115,000 MILES • V8 • 4WD • AUTOMATIC
PINHIGHER
I have a blow spark plug, #4 on the passenger side(to the rear of the motor). Need a rough estimate to properly fix, and what steps will I need to make sure are taken to prevent it from happening again?
May 16, 2010 at 5:59 PM
Can you tell me if this is on a 5.4L V8?
May 17, 2010 at 6:30 AM
PINHIGHER
It is a 5.4 Ltr V8
May 17, 2010 at 8:38 AM
I hate to say it because I own one too, but this is a somewhat common problem. The threads for the plugs are not long enough and as a result, the plug blows out. It has happened quite often.
To properly fix it, the head will need removed, the stripped threads drilled out, retapped, and a helicoil installed. All of about 5 dollars for the helicoil that actually fixes the problem, but then gaskets need replaced. I would figure you'll have around 500.00 into parts and labor when it's all said and done. Keep in mind I don't know where you live or the average shop rates, so I could be off on price for you.
PS: There is no recall on this problem.
May 17, 2010 at 10:35 AM
PINHIGHER
Thank you, that is about what I was figuring.
May 17, 2010 at 1:56 PM
Good luck and let us know how it goes.
May 18, 2010 at 7:24 AM
