1998 Ford F150 Replaced Flywheel
1998 FORD F-150
190,000 MILES • V8 • 2WD • AUTOMATIC
FOSBORNE
Replaced flywheel and now the truck will not go into gear. Starts fine and not aking any noise. Could it be that the tork converter is not seated??
Nov 8, 2008 at 5:39 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be thinking that there is a problem with the torque converter and the pump drive, but normally if the converter is not seated fully you have a problem with it sitting to far out, with the transmission bolted up and the torque converter free it should spin freely, and bot be hard against the drive plate, check this out first.
Mark (mhpautos)
Nov 8, 2008 at 6:33 PM
