1998 Ford F150 how do I replace the solenoid on the starter
1998 FORD F-150
160,233 MILES • V8 • 4WD • AUTOMATIC
CHICO19699
I can jump across the soleniod with a screwdriver and the motor will start. Are their more than one solenids and if so were are is the other? How do I change the one on the starter, do I have to pull the starter?
May 13, 2010 at 9:11 AM
If you're referring the solenoid that you short out with the screwdriver as the starter relay and it cranks the engine over-check and test the transmission range switch and ignition switch.
May 13, 2010 at 10:54 AM
