front end vibration has standard tires and wheels?
1998 FORD F-150
158,000 MILES • V8 • 2WD • AUTOMATIC
SEASPORT
  • 8 POSTS
The ford 150 has standard tires and wheels and has recently developed a small vibration when turning a corner from a dead stop. The vibration stops when the wheel is straightened. I jacked it up and have no play in the tires. At high speed there are no problems at all. I have had the alignment, some front end work and the stabilizer sway bar bolts replaced and I still notice the vibration. Any clues ?
Dec 13, 2007 at 2:20 PM
2CARPRO JACK
  • 11,533 POSTS
That have Rack and Pinion steering? Have seen many Fords "chatter" when turning the wheel, steering box usually takes care of the problem.
Dec 20, 2007 at 4:06 PM
Also, I would flush the steering fluid because then it gets old it can chatter, here is a video to show you how on a similar truck but the procedure is the same.
https://youtu.be/lkWbV48kfLU?si=Ii-J32nCyzlR7Qp6
Sep 19, 2024 at 3:07 PM
