1998 Ford F150 Engine knock
1998 FORD F-150
113,000 MILES • V8 • 4WD • AUTOMATIC
MCOX0112
Now that the weather is getting cold I noticed that when I start my truck I'm getting a knocking sound from the engine. It sounds to loud to be a valve tap.
Nov 4, 2008 at 6:33 AM
MASTERTECHTIM
  • 4,750 POSTS
try a lower viscosity oil, like 5/30, this should help with cold start ups. also i found that a exhasut manifold leak is misinterpretated for a engine knock and goes away when warm because the manifold expands when warm so doulble check for a exhaust leak
Nov 4, 2008 at 6:45 AM
MASTERTECHTIM
  • 4,750 POSTS
5/20 weight oil. if you go to a quickie oil change place they might be installing 10/40 or 10/30
Nov 4, 2008 at 6:47 AM
MCOX0112
I change my own oil and I already use 5W30 but I will check for an exhaust manifold leak. Thanks
Nov 4, 2008 at 7:02 AM
