Hi, locked in low range 4 wheel drive, can't get it out!!??
HELP PLEASE!
Aug 24, 2010 at 2:32 PM
CERTIFIED EXPERT
Do you have the electronic shift 4wd? Is so, have you checked to see if the actuator is getting power on the transfer case?
Aug 24, 2010 at 8:30 PM
FORE
MEMBER
Yes it is electionic,I checked the electric vacuum pump by disconnecting it, and operating the switch, its working fine but still stuck in low range 4 wheel drive. The lever works back and forth but still stuck!?
Aug 24, 2010 at 9:45 PM
CERTIFIED EXPERT
What lever? Does it have the push button 4wd or the lever on the floor?
Aug 24, 2010 at 10:59 PM
FORE
MEMBER
It has the dial switch on the dash. I would pay you so much more but down to my last dollar and will donate more later more I promise. Thanks man!
Aug 24, 2010 at 11:08 PM
CERTIFIED EXPERT
Please don't worry about that. We are here to help. As far as the 4wd, there is a 4wd actuator on the transfer case. When you turn the knob, it sends power to the actuator. I need to know if you are getting power to that part when the knob is turned. It is not uncommon for them to go bad.
Aug 25, 2010 at 11:47 AM
FORE
MEMBER
Yes I am getting power. And thanks again so much.
Aug 25, 2010 at 2:04 PM
FORE
MEMBER
Still stuck! UGH!
Aug 25, 2010 at 7:32 PM
FORE
MEMBER
Hi guys, are you still there cause I am still stuck in 4 low. Been great so far and thanks again.
