Brakes problem
1997 Ford F150 6 cyl Four Wheel Drive Manual 150k miles
I have a 97 f150 4x4. I had a problem with the front brakes, when you drove the truck it started out fine, the longer I drove, the harder the pedal would get, It would eventially lock the front brakes to the point I could not drive it.
I then replaced the front brake lines and hoses, rebuilt the calipers and put on new pads.
I thought with what I did, it would fix the problem, however during the test drive after these repairs, the problem is still there. The longer you drive, the harder the pedal gets and I know the front brakes are dragging badly. Any ideas what to try next??
Thank You in advance
Nov 1, 2009 at 12:30 PM
