1997 Ford F150 rear drum brake over adjust
1997 FORD F-150
185,000 MILES • V8 • 4WD • AUTOMATIC
DAVID CONRAD
The right (passenger side) rear drum brake has over adjusted.
Corrective action taken: On 1/25/08 I backed off the adjustment screw and oiled the pivot points but not the adjustement screw. With a soft mallet I tapped the shoes to knock out any crud. About 50% of the pad is left. I changed the brake shoes about 3 years ago but did not turn the drumbs.
2/1/08 I noticed the right drum is hot and the left is cool. I also think it is starting to drag again.
What will cause the brakes to over adjust?
Feb 1, 2008 at 6:35 AM
98RANGERXLT
  • 301 POSTS
Usually a bad self adjuster.
Feb 1, 2008 at 8:27 PM
