1997 Ford F150 LOW BRAKE PEDAL
1997 FORD F-150
161,000 MILES • V8 • 4WD • AUTOMATIC
BIGORANGE16
When brakes are applied the pedal goes down and activate the ABS. I have bleed the front brakes but not the rear. The rear brakes are drum.
Jan 23, 2009 at 4:20 PM
Hi:
Make sure there are no leaks and the master cylender is full. Next, properly adjust the rear brakes. Also, when you bleed the brakes, start at the wheel furthest away from the master cylender and work toward it. Did you do work on the system for you to consider bleeding them necessary?
Let me know if this works.
Jan 26, 2009 at 4:41 PM
BIGORANGE16
Joe,
Thank you for replying. No I did not work on the system. I just bought the truck and the brakes felt soft. First thing that came to mind was air in the lines.I was going to pull the rear drums , but it looks like there is something in front of the drum and it looks like it requires a special tool to remove it.
Jan 26, 2009 at 6:26 PM
On an F150, i can't think of anything that needs removed. Regardless, lift the rear wheels off the ground and safely support the vehicle. Then see of there is any drag on the rear wheels. If there isn't try to adjust the rear brakes through the backing plate. Adjust them up until there is a slight drag on both wheels. Next, get in and pump the brakes a couple times to center the shoes. Again, check for drag on the wheels. If you no longer have any, repeat the process until the shoes are centered and have a slight drag.
Let me know if this helps.
joe
Jan 26, 2009 at 6:58 PM
