DO NOT reuse same bolts.
Tighten new bolts in the following sequence:
STEP 1 = 14 ft lbs (19 Nm)
STEP 2 = 29 ft lbs (39 Nm)
STEP 3 = 36 ft lbs (49 Nm)
STEP 4 = Loosen 3 Revolutions (DO NOT loosen all bolts at the same time. Loosen and torque to specs one bolt at a time.)
STEP 5 = Short Bolt - 15-32 ft lbs (20 - 43 Nm)
Long Bolt - 30-36 ft lbs ( 41 - 49 Nm)
STEP 6 = Additional 175 - 185 Degrees
Hope this helps.
Dec 4, 2008 at 12:46 AM
