1997 Ford F150 DTC
1997 FORD F-150
130,000 MILES • V8 • 2WD • AUTOMATIC
COLBYWWILSON
  • 4 POSTS
My 1998 F-150 has a code stored that I don't understand or know how tp fix. What do I need to correct if I am getting a "P1780" Code.
Thanks,
Nov 7, 2008 at 8:06 AM
MASTERTECHTIM
  • 4,750 POSTS
https://www.2carpros.com/forum/automotive_pictures/139033_gov_5.jpg
if this has a overdrive on/off switch on shifter handle i would suspect its bad.
Nov 7, 2008 at 8:23 AM
COLBYWWILSON
  • 4 POSTS
Thanks,
I do have a switch in the column for OD on\off but it is still functioning. Could it still be the problem component even if it is working when toggled?
Nov 7, 2008 at 10:21 AM
MASTERTECHTIM
  • 4,750 POSTS
i just relooked it up and found a long diagnostic chart that points to the od switch. thats all i have seen go wrong so it would be a good place to start. it is possible it is something else but you have to play the odds on this one, i think and put in the switch.
Nov 8, 2008 at 2:03 PM
