I have a 1997 Ford F150 V8 4.6L with 160,000 miles.
The brake lights do not go on when the pedal is depressed. This is causing a problem moving the gearshift from Park and I have had to remove the 5 amp Brake Shift Interlock Fuse to allow the gearshift to move. What should I check. Thanks.
May 24, 2007 at 11:56 AM
