1997 Ford F150 Axle oil on wheel
1997 FORD F-150
ZOMBU
Drive Train Axles Bearings problem
1997 Ford F150 V8 Four Wheel Drive Automatic
There is gear oil all over my one rear tire.I pulled the one tire off;then the heb that cover with oil; Now I see my brakes also cover with gear oil How do I change the seal / bearings?
Mar 24, 2010 at 8:49 AM
DOCFIXIT
  • 18,828 POSTS
Need to pull cover off differential housing , then remove pinion shaft push in on axle remove C clip remove axle. Remove seal ans install new.
Mar 24, 2010 at 12:42 PM
