1997 Ford F-150 Oil leak
1997 FORD F-150
120,000 MILES • V8 • 4WD • AUTOMATIC
CAMOPAINT0707
I have an oil leak coming from what I believe is my timing chain cover. I noticed the tensioner is rubbing against it and has burnt a hole right through it. Also there is a strange sound coming from my front wheels. It almost sounds like they are grinding or something when I drive and they also squeak if I rock them back and forth when the truck is off. What are the part numbers for the tensioner and timing chain cover if you think thats the issue. What is the issue with the sound from my wheels?
Oct 5, 2010 at 7:19 PM
BLACKOP555
  • 10,386 POSTS
i wouldnt be checking the timing chain or tensioner to be causing the problem. i think your best bet before doing anything is to measure cam and crank endplay to see if that was causing it to rock and wear a hole.
Oct 5, 2010 at 10:13 PM
CAMOPAINT0707
it was the timing chain cover that has a hole in it.
Oct 7, 2010 at 12:16 AM
BLACKOP555
  • 10,386 POSTS
i am aware of that. i was stating what could have caused the hole inside of the cover. to prevent it from coming back. unless you know how the cover was worn?
Oct 7, 2010 at 7:26 PM
