1997 Ford F-150 not running right
1997 FORD F-150
JJAGSPAPA
I am working on a 1997 Ford F-150 4.2. I have put on a new fuel pump, gave it a tune up and put in a new computer. I am still having trouble with it. It runs really rough. After it idles for a little while the manifolds glow cherry red. Someone mentioned it might be out of time, but it doesn't seem to be. Someone else said it sounds like it is getting to much fuel. Another person that I talked to owns one of these and has had the same problem. They replaces several sensors and the computer. Several thousand dollars later they are still having the same problem.
Nov 28, 2007 at 12:23 PM
BLACKOP555
  • 10,386 POSTS
Sounds to me that it is out of timing, is there any trouble codes, that should tell you if its over rich. Usually when the manifolds are cherry red it is a sign over the timing being out.
Dec 5, 2007 at 8:24 PM
FLEXY5
  • 512 POSTS
Check the catalytic converters. If it doesn't seem out of time, look for a restriction. it sounds constipated!! LOL
Dec 8, 2007 at 3:14 PM
