1996 Ford F150 turn on igntion car makes no sound
1996 FORD F-150
114,000 MILES • V8 • FWD • AUTOMATIC
SOSEWLINDA
  • 4 POSTS
put key in, turn on, all lights and bells sound , no cranking sound. I checked ignition and electrcal module under ignition.Good Tested silenoid good( I have to touch with screw driver so it will start with key in on postions) Tested starter good. What else can it be???
Dec 1, 2009 at 5:58 PM
Have you checked the ignition switch?
Dec 4, 2009 at 7:39 AM
SOSEWLINDA
  • 4 POSTS
I have replaced ignition switch and module (under switch) when it first started. same problem so i started testing parts. . I will now start trace testing powerflow to and from starter selenoid. will get back to you later
Dec 4, 2009 at 10:56 AM
