1996 Ford F150 Throttle
1996 FORD F-150
109,000 MILES • V8 • 4WD • AUTOMATIC
JOE STEINER
Hello
I noticed coolant spraying onto the engine. Took to local mechanic who found coolant coming from what they thought was a freeze plug on the throttle body They say they cannot get a new or used throttle body for replacement but will "work on it" OR can install a used throttle body from a different size [larger] engine.
Local Ford dealer said they don't don't replace throttle bodies for this engine.
Please advise?
Thanks
Aug 4, 2008 at 10:37 AM
2CARPRO JACK
  • 11,533 POSTS
Why dont they replace them? I have had to for being worn out and for coolant erosion. Have you seen where the leak is for yourself? Might want to just so you can explain to the Ford parts guy what it is you need, I dont recall there being a freeze plug on the throttle body, and if there is, it should be serviceable
Aug 5, 2008 at 7:55 AM
