1996 Ford F150 Loosing coolant
1996 FORD F-150
MCMNASH
Engine Cooling problem
1996 Ford F150 V8 Two Wheel Drive Automatic 120k miles
Vehicle looses coolant at the rate of about 3 cups per 100 miles. Have replaced water pump, cracked radiator and hoses. No visible drips, runs or pooling of water under vehicle. No water in oil pan. No water anywhere. I noticed that there are water lines running to the throttle body. What is the purpose? Is there possibly a freeze plug somewhere on the intake that could be leaking? Thank you for your response.
Sep 4, 2008 at 7:52 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would have the cooling system pressure tested first, this may show op a small leak that may otherwise go unnoticed.
Mark (mhpautos)
Sep 5, 2008 at 4:06 AM
MCMNASH
The dealer pressure tested the system before replacing the water pump, hoses, etc. They evidently did not find the leak. Thanks for your reply.
Sep 5, 2008 at 7:24 AM
