u have to remove cluster out and bulbs in the back of it
1.Disconnect negative battery cable. Unsnap and remove instrument cluster opening finish panels.
2.On A/T models, remove loop on shift indicator cable from ball stud on shift lever.
3.Remove thumbwheel bracket screw.
. Detach bracket from steering column.
Remove cluster finish panel.
Remove 4 cluster screws.
Pull cluster away from panel, bottom first. Unplug connectors and remove instrument cluster.
Remove bulb and replace
To install, reverse removal procedure.
Sep 21, 2008 at 5:55 AM
