i have a 1996 ford f-150. 5.0 v8. 4x4. automatic. everything is completely stock. my check engine light came on about 2 weeks ago for the first time. i didnt think much of it cause it ran just the same, till i figured out that im only getting roughly 8 miles to a gallon of fuel. then over time my truck statred idleing lower and lower and now is down just under 500rpm. i went and had the code read and it came back as either too high or too low fuel pressure, a leaky fuel injector, vacuum leak, or a leaking or defective fuel pressure regulator or fuel vacuum diaphram thingy. the truck would drive fine, it never once stalled and actually seemed to have more power im guessing due to the amount of fuel useage. now just today, while driving about 55mph the first time and only 25mph the second, both were right around 1500rpm's, the engine would shake very violently as if to have ran out of fuel and was only firing on a few of the cylinders. any info, suggestions, or things to try would be greatly appreciated. also any suggestions on how to test any of the item stated above like the leaky fuel injector would be a big help. thanks, justin.
Aug 1, 2010 at 8:56 PM
