1996 Ford F150
1996 FORD F-150
BRANDONN
Air Conditioning problem
1996 Ford F150 6 cyl Four Wheel Drive Manual
how do i recharge my air conditioner
Aug 16, 2008 at 10:33 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
To do this correctly you will first need to vacuum down the system and make sure that there is no leaks, then with a suitable set of pressure gauges you will then add refrigerant into the low pressure side. to make sure that the system is ok i would get your mechanic to do this job.
mark (mhpautos)
Aug 17, 2008 at 2:26 AM
