1996 Ford F-150 how to change engine oil and what type of o
1996 FORD F-150
MPNAVIN
1996 Ford F-150
how to change engine oil and what type of oil filter to use
Sep 28, 2010 at 4:11 PM
BILLYMAC
  • 2,204 POSTS
Hi
Ilike motorcraft filters and so does ford.
to change oil get a drain pan remove the drain plug drain oil out.
when all out.. wipe down where drain plug goes. put oil plug back in tighten it but don't over tighten . now remove oil filter move pan so it will drain filter.
take new filter put a little oil on the rubber gasket check old filter make sure rubber gasket came off with filter.
install new filter tighten hand tight as in as tight as you can by hand.. put oil in put 6 qts start truck let run a few secs.
shut off check dip stick add as you need
Sep 28, 2010 at 4:19 PM
