1995 Ford F150 transmission leakage
1995 FORD F-150
165,000 MILES • V8 • 2WD • AUTOMATIC
RONALDSTEP
I recently noticed my truck was hessitating going into drive so I checked the level of the fluid it was low, went under the truck and noticed fluid all over the underside of the truck, it seems the fluid is coming from the top of the trans, what could it be coming from?
Jan 28, 2008 at 7:23 PM
INDYUKE
  • 416 POSTS
Most likely it's coming from the overflow tube. Normally happens when your transmission gets hot.
Is there a way you can get a small mirror on a stick and put it up there to see if you can see exactly where it's coming from? Let us know.
Jan 28, 2008 at 10:17 PM
