Hey,
Other than this problem my truck works fine (minus the front tank fuel filter which will be replaced tomorrow). Most of the time it drives great for a truck with 200K+ miles on it. But every now and then at about 25mph it wont shift for a while... you either havta press the gas pedal till it jerks to the next gear or release the pedal and let it shift into the next gear.(The overdrive "off" light flashes while truck is acting up) But once past that point it runs normal untill you go back below 25mph. Is there a way to fix this problem, that hopefully isnt going to cost me an arm and a leg?
Thanks
-Seth
Thanks
-Seth
Mar 20, 2010 at 11:57 PM
