1995 Ford F150 slave cylinder/clutch??
1995 FORD F-150
160,000 MILES • 4 CYL • 2WD • MANUAL
TUPELOBREEZE
1. The clutch pedal hits the floor
2. The engine will start sometimes and go up to 3rd gear but not beyond.
3. Brake fluid has been added
4. The slave cylinder has been replaced one time already.
5. Noticed problem after taking truck to an "Express Lube" for an oil change, etc.
What do I need to do to get it running at 100%?
Oct 30, 2008 at 2:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
When you say the pedal hits the floor, dose it drop or is the pedal presser as you push it down? if no pressure check the fluid level and check again for a faulty master or slave, check this first.
Mark (mhpautos)
Oct 30, 2008 at 4:18 PM
