1995 Ford F150 Replacement of Gas Tank
1995 FORD F-150
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
PROJECTGUY
I have a Ford F150 with a leaky rear fuel tank. Can I just remove the rear tank and plug the lines or will this cause a problem? Is there any information on how to properly remove/replace a fuel tank on a Ford F150?
Apr 19, 2008 at 8:51 PM
BLACKOP555
  • 10,386 POSTS
you can leave the tank on there and just use the front tank, dont have to drop it and plug it, you could if you wanted.
to replace a tank just disconnect all hses and wires and cut the straps, and your done.
Apr 20, 2008 at 9:11 AM
