I was wondering if there is a correct proceedure to remove and install a new side gas tank in my 1995 F150 SW base?
Oct 17, 2008 at 10:10 AM
BLACKOP555
CERTIFIED EXPERT
some disconnect everythign first then drop it down. some drop it down support it then disconnect everything. all depends on what you find easiest. be sure to bleed the system of pressure before disconnecting the lines.
