1995 Ford F150 Need new gas tank installed
1995 FORD F-150
148,000 MILES • V8 • 2WD • AUTOMATIC
RYANSRAFT
I was wondering if there is a correct proceedure to remove and install a new side gas tank in my 1995 F150 SW base?
Oct 17, 2008 at 10:10 AM
BLACKOP555
  • 10,386 POSTS
some disconnect everythign first then drop it down. some drop it down support it then disconnect everything. all depends on what you find easiest. be sure to bleed the system of pressure before disconnecting the lines.
Nov 23, 2008 at 8:57 AM
