Not to bad just alot of elbow grease. You will need to remove the rear driveline and then unplug the rear abs sensor and brake line to the rear end. Then unbolt the rear end via the ubolts and roll it out. Then remove the eye bolts at the frame and the shackle on both sides and replace in reverse order.
May 19, 2009 at 10:21 PM
