Purchased this vehicle used in 2004.
Apparently this problem existed prior to my purchase and had been looked at by Ford more than once. They could not find the problem. Transmission mechanic says tranny is fine.
Engine will over rev and Transmission will shift hard from 1st to 2nd. Might happen today and not happen again for 6 weeks and might happen every day for a week. MLPS switch on tranny was replaced --did not fix it. Replaced the Speed sensor in differential and made it worse. Put old sensor back in. 2 weeks ago replaced the PCM. Still have a problem.
Problem is worse when vehicle sits out in hot sun all day. At 3 am when I get off work it works perfectly.
Also, seems to happen more when I am pulling a trailer.
Your answer must seem plausible-- guesses won't cut it.
Aug 30, 2010 at 1:37 PM
