fuse 9 in power distribution box keeps blowing?
1995 FORD F-150
107,000 MILES • V8 • 4WD • AUTOMATIC
SILENPRO
do you have a wiring diagram for power distribution box. a95 should have letters but my cover for the PDB has numbers. fuse 9 keeps blowing when i turn the key to ignition. what does fuse #9 power. thank you
Jan 31, 2008 at 10:02 AM
98RANGERXLT
  • 301 POSTS
The #9 fuse just does the power point socket, please check out the wiring diagrams below to confirm. Check out the images (below). Please let us know what happens.
Feb 1, 2008 at 8:16 PM
SILENPRO
[quote:5cf25a2253="Fordman16"]If you have the original owners manual it should tell you.[/quote:5cf25a2253]
i found the short, when i unplug the transmission plug the fuse stops blowing. the wiring is fine. the plug for the gear lelector is fine and also the speed sensor. it only blows when i plug the transmission plug.. could a valve body do this.
Feb 2, 2008 at 6:36 PM
SILENPRO
Feb 4, 2008 at 8:48 AM
I don't think so, this fuse powers the cigarette lighter? Are you sure you have the right fuse #?
Dec 2, 2024 at 1:17 PM
