1994 Ford F150 WONT PASS SMOG
1994 FORD F-150
120,000 MILES • V8 • 2WD • AUTOMATIC
NATE4545
  • 4 POSTS
HIGH IDLE SPEED 1200-1300 RPM. HYDROCARBONS TOO HIGH. WHEN IDLE IS RAISED IDLE A LITTLE SLOW TO COME BACK DOWN.
Jan 14, 2008 at 11:44 PM
INDYUKE
  • 416 POSTS
Check engine light on?
Jan 15, 2008 at 5:19 PM
NATE4545
  • 4 POSTS
NO CHECK ENGINE LIGHT IS NOT ON, BUT IT DOES WORK.
Jan 18, 2008 at 7:17 PM
INDYUKE
  • 416 POSTS
Two things to check first. The coolant temp sensor may be bad. When they go bad, the computer that's reading the info coming from them sees the engine as never reaching operating temp, so it keeps the cold idle and mixture settings.
The IAC motor may need to be cleaned as well. It's the tubular looking thing alongside the throttle body. Blasting the inside of it with carb cleaner until it runs out clear seems to work really well. Don't get the little motor wet though. Let us know.
Jan 18, 2008 at 8:15 PM
NATE4545
  • 4 POSTS
I replaced the coolant sensor, tried cleaning the AIC, still dirty inside so I replaced that also. Runs the same, idles 1100 rpm or so. I also found a spark like an ignition spark between the alternater and the alt mount, I can see it sometimes, but can hear it real good. I unplugged the 3 wire plug on the alternater and it stopped: plugged it back in and it started up again. Check all the grounds, they are fine. I think this is two separate problems?
Jan 19, 2008 at 10:17 PM
INDYUKE
  • 416 POSTS
The charging circuit wouldn't effect idle speed any, unless there was a very large load on the alternator that would drop idle down 100-200rpm, but it wouldn't cause a high idle. I think you are right... it's a seperate problem.
As far as the high idle, check all the vacuum lines and the throttle position sensor. A vacuum leak most likely won't contribute to high emissions by itself, but it would cause a high idle. The throttle position sensor idle voltage should be almost exactly 0.96 volts. Other things you could check are:
intake air temp sensor. This sensor calculates how dense the incoming air based on it's temperature.
Whether the throttle is closing all the way. Maybe a binding throttle cable. Do NOT adjust the little screw that rests against throttle. That is factory set... the computer is responsible for idle speed based on the input of various sensors. Let us know.
Jan 20, 2008 at 4:47 PM
NATE4545
  • 4 POSTS
Its been awhile, I am going to check the TPS, but how do I check the air temp sensor, Thanks
Aug 18, 2008 at 7:37 PM
