1994 Ford F150 transmission disengages from engine
1994 FORD F-150
73,000 MILES • V8 • 4WD • AUTOMATIC
CLARK THOMAS
While driving the engine will disengage from the transmission. Usually when slowing and then stepping on the gas the truck will act like I shifted it into neutral. It will also not shift at the correct rpms. This does not happen all the time. I can use it for 30 miles perfect and all of a sudden problems. I have had it at a shop many times over the past 5 years. They have tried everything except change the trans because they feel the trans is fine.
It is frustrating because there seems to be no answer. HELP
Mar 27, 2010 at 4:08 PM
MICK79
i have the same truck and exact problem. it is intermitant yet more frequent if slightly low on fluid.
if you find a cure i would be most happy to here.
i found that removing the negative battery cable for a few minutes will give me more miles between issues. hope this helps
Mar 29, 2010 at 6:37 PM
CLARK THOMAS
Thanks for the reply. I will post my findings if i am lucky enough to fix this problem. I replaced the battery and still have the same problem.
Mar 29, 2010 at 7:29 PM
