While driving the engine will disengage from the transmission. Usually when slowing and then stepping on the gas the truck will act like I shifted it into neutral. It will also not shift at the correct rpms. This does not happen all the time. I can use it for 30 miles perfect and all of a sudden problems. I have had it at a shop many times over the past 5 years. They have tried everything except change the trans because they feel the trans is fine.
It is frustrating because there seems to be no answer. HELP
Mar 27, 2010 at 4:08 PM
