1994 Ford F150 replace rear freeze plug
1994 FORD F-150
353,000 MILES • V8 • 2WD • AUTOMATIC
WANDA JENKINS SMITH
how do I replace the rear freeze plug on the passenger side
Mar 4, 2010 at 8:43 AM
DEACONWIDOW
The way I did it was pulled the carpet back under dash and cut a hole in floor using a die grinder the hole was mabey 4x4 then I repaired hole with some good old fashioned Duct tape replaced the carpet and filled her up. no is the wiser, the other method is to pull the exhaust loosen the tranny and let it puul the motor down, then you have access, my way took 35min
Mar 25, 2011 at 8:40 PM
